How to turn BIN and CUE files into programs?
as per the title…i have no idea how to actually extract the information i need from these files to get to the program…prease help :eekdance:
when i had bin and cue files…i would alwas burn them onto CD as a program then run in from the CD
you burn them with alcohol120, or mount them with the same program, you dont extract anything, just burn or mount.
it’s a disc image, just like an iso, etc. – just mount it with daemon tools.
http://www.daemon-tools.cc/dtcc/download.php?mode=ViewCategory&catid=5
maybe you should say what it is you’re trying to use… like an application, game, movie, etc etc etc. if it’s an OS or something obviously burn it, if it’s a movie or something just mount it.
:word: Get a program that supports burning cue files. When you select the cue file to burn it will grab info from the Bin file and burn whatever it is that you have.
bin files are image files. the cue file basically points progrmas over to the bin file which is the actual disk image. use above suggestions for use.
:word: What he said
theres a program called undisker so you can open .iso’s without burning them. you can then run or extract w.e you need
Winrar opens isos as well.
:word: , also if u just mount it with daemon u can just copy paste the files elsewhere, bout a million and a half ways to do it, watever floats ur boat
mounting > burning. less wasted CD media.
