The entire drivetrain is up for grabs from the JDM 240 I am parting. Please do your homework whether some of the parts will fit.
Rear Brakes w/rotors - 100.00
JDM Master Cylinder - 50.00 Perfect for big turbo setups looking to relocate lines to the left side of the MC. Will require line refitting.
JDM Brake Booster - 50.00 Perfect for anyone running 300ZX and S14 brakes. Slimmer than the USDM one.
Slave Cylinder - 40.00 Perfect for 5spd swap.
JDM Clutch and brake pedals - 75.00 These will fit USDM cars. I recommend using just the clutch pedal and cutting the stock auto pedal to save time. Will sell clutch pedal for 50.00
JDM Rear subframe w/LSD and axles - 300.00
rear hub assemblies and lower arms - no rust - 60.00
Rear arms - no rust - 50.00 Not seperating
Rear parking brake cables - 50.00 MINT
S14 5-spd rubber shift boot and trim - 50.00 rare and hard to find.
S14 JDM Driveshaft NON ABS - In perfect condition. 200.00
S14 Front Hub assembly - 50.00 No rust
Rear Tein coilovers, front KG/MM shocks w/springs - Good setup for some looking for a lowered stance for cheap and car actually rode well on this setup. The JDM cats knew what they were doing
400.00
S14 5 lug hub F&R - 200.00
JDM S14 4-pot calipers (same as 300ZX brakes) and rotors. Complete with lines so its a bolt on affair. 375.00
SR AC parts - 100.00
Clutch cylinder - 40.00
JDM S14 chassis, very clean, off road use only. 500.00 What you see is what youll get. Inquire for more details.
