Does anyone have a cheap car for sale !can use Must be a front wheel drive 4 cylinder,auto or a stick and max wheelbase of 150 inches!!! Looking for a Chevy cavalier or ford probe !! or anything else along those lines!! I was going to use a 1991 Honda accord but the wheelbase is 2 inches to long!! Ill trade this car for something also!!
vw’s were competitive in that class. if u go that way, ill help ya out part wise via interswapping oem parts to cheat legally as all shit is oem, and if someone would protest and tear you down, it is all oem-- so what can they say??? could easily interchange parts and get you up to a high compression high reving sohc 8v motor via 16v bottom end, solid lifter head, run a european fuel distributor, dual outlet manifold (vw oem header) and european cis (or early vw cis systems-- no o2 sensor basically a mechanical fuel injection 1 step above carbs).
Shit, could even play w/ spring rates to setup the car suspenion for corners, lol
all that could be done probably for under 400 bucks too. look for a rabbit, older the better a they have less saftey shit.
lastly, doesnt jennerstown allow dohc cars? if that is the case, then it opens up alot of possibilities.
Why not go to there website and find out if anyone has 1 for sale on there.
