stock injectors/fuel rail take it for 15$
They all work right? The injectors are already in the rail and did not leak during their previous use, correct? Also, how much mileage on the injectors?
I call dibs. I’m coming back to Toronto today from Waterloo. I might make the drive to Oshawa if I am CERTAIN these injectors work fine.
they were working great when pulled so yes, the mileage was 176xx on the motor when pulled so about that the only thing i dont have is the cushions so if you have that your golden(the black rings that the injector ends sit in between the intake and injector end
