KA24DE/SR20 Parts
1991 KA24de engine, comes with all accesories ps pump, alternator etc. The engine came from a Automatic car with 200 xxx kms, compressions tested before pulling from the car 178 psi across all 4 cylinders. Strong engine perfect for a KA-T
$250
S13 KA24DE engine harness complete $100
S13 KA24DE MAF $40
S13 KA24DE ECU $70
S13 KA24DE Coil + Ignitor $40
WILLING TO DO A PACKAGED DEAL ALSO
KA24E/DE Water Pump $20
KA24DE Flywheel $40
KA24DE Transmission Shield/ Spacer $30
S14 KA24DE Flywheel Sensor $30
S13 Speed Sensor $20
S13/14 Knock sensor $20
KA/SR Clutch Slave Cylinder $20
S14 SR20DET Flywheel $50
S13/14 Parts
S13 SPL Front fender braces NEW $140
The front fender brace installs inside the fender to reduce chassis flex between the front section of the car and the mid/rear section of the car. This reinforces the chassis structure where it is weakest - about the firewall, between the cockpit and the engine bay.
NGR Aluminum Front STB work for S13 and S14 $60
S13 Coupe JDM tail lights $50
S13 91-94 Lip Same as Bings $240
S13 Coupe rear valence $100
S13/14 Energy Suspension TC Rod Bushings $30
S14 Energy Suspension Front + Rear Sway bar bushing $30
S13 Radio brackets $10
S13 Coupe Interior Quarter panels $30
JDM S13 Coupe Trunklid Trim (Only came in Silvias) $60
RB25 Parts
ARC Blow Off Valve For RB25 possibly RB20 also $60
OEM Nissan head gasket for RB25DET $60
Stock RB25/26 oil pump (Good condition) $50
RB25DET Short Shifter $80
MISC Parts
GT2871R .86 Blown $100
Z32 300ZX 5 lug TT Rear Hubs/ Bearings (approx100km) $150
Autometer Lunar Air/Fuel Guage $30
RCI Race Harness $40
Z32 Brake master Cylinder No leaks $100
Also have the Z32 Brake Vacuum Booster $50
Alpine Type S Speakers Fits S13 Coupe doors $50
Electric fan, Pulls crazy, Perfect size for Skyline radiators $50
S14 12inch 2 speed fan, mounting bracket cut off $20
OEM 350Z Clutch Great Shape Lots of lining left $100
T25 Turbo Gasket $10
T3 Oil Drain flange $15
All prices OBO
LOCATED IN EDMONTON, CANADA WILLING TO SHIP ON MOST PARTS
