ok fuel speclists!
i got the y block RUS-650360 Fuel Block, Y Style, 1/2" Inlet w/ Dual 3/8" Outlets, Billet Aluminum, Red $29.95
i need the two brass things and the top one!
http://www.ls1tech.com/forums/attachment.php?attachmentid=15302
to create
http://www.ls1tech.com/forums/attachment.php?attachmentid=15303
i stretched the 5/16 hose over a 3/8 barb because i couldnt find a 3/8 npt to 5/16 barb anywhere… no biggie
the outlet is 1/2 npt because that easily adapted to my -8 bulkhead fitting with a 1/2 npt male to -8 female without choking it down like the 3/8 would… and is easily upgraded if i ever need -10 line
and i need this -8 angled bulk head…
http://www.cofba.org/users/smokinhawk/fuelsystem/8an-pump.jpg
can any one find part numbers out of summit or have any of these…
last things i need!!!
http://www.russellperformance.com/auto/adapt/adapt_fit_an.shtml
first fitting on top that you are looking for
http://www.motormitedormancatalog.com/item.wws?sku=43280&mfr=DORMAN&cookieID=1F21DUBRX1F21DUIYL&clientid=motormitedorman&clientid=motormitedorman
i think this is what you are looking for. find a parts store that sells dorman products
and for russell, use the part number to call your supplier
hope this helps
-8 1/2" 614228 that looks just like it!!! thanks!!!
this looks exaclt like the other two i need but the only thing i notice is that where the hose will connect its flaired not barbed?? do you think that will make a difference? just use a small hose clamp?
anyone know this or where to order these i wanna order these today!
thanks man!
i like to use fuel injection hose clamps on something like that. they clamp much better. they look like a small solid band with a small bolt running through it. any part store will have them. go to a better part store and ask if they have the dorman parts book to see for the brass fittings. also just an idea check at lowes they have a lot of odd hard to find fittings
awsome ill reasurch on the web and see if i can get them somewhere online!
unless anyone knows a place.
its about time to get my ass in gear and get this bitch done.
