$300 or trade for xbox360, ipod ect. Let me know what you got.
Im selling my old car subwoofer set up. These are top quality USA made American Bass Subs that they don’t make anymore. They sound wonderful and hit hard. They are alittle beat up cosmetically but sound and function perfect still.
1 Sony Explode XM-475GSX 800 watt car amplifier. Bought new around 2002 at Best Buy for $280. Can be used as a 2/3 or 4 channel amp.
1 Qlogic 2x12" carpeted speaker box. Its sealed but has the plugs and port tubes to convert it to ported.
2 American Bass VFL 12" dual voice coil 6ohm subwoofers. These are high quality subs made in the USA.
Willing to trade for video game system, electronics, ipod, guitars, drums or other music equipment,ect. Let me know what you got.
Specs are as follows.
American Bass VFL Series DVC Subwoofers In 12, And 15-Inch Sizes
Common Features:
- Dual 3" 6 Ohm High Temperature Voice Coils.
- 1.4" Wide Multilayer Foam Surround for Better Stable Linear Exclusion.
- Non-Pressed Black Treated Paper Cone.
- Vented Deep Bumped Back Plate
- 180 Ounce Double Stacked Magnet Structure
- Dual Black Mirror-Image Spiders For Linear Stability.
- Sleeved High Power Tinsel Lead Wires to resist Lead breakage.
- Blackened Motor Parts for Superior Heat Dissipation & Long Life
- Hyper extended Pole Piece Increases Accuracy, raises Induction.
- Deep Bumped Back Plate to Increase Power Handling.
- Uni-Rubber Gasket for Airtight Seal in Mounting.
#VFL12 - 12" 1500 Watt Woofer
- 750 Watts RMS
- 180 Ounce Magnet
- Efficiency: 91.75dB
List Price: 324.95 Each Brand new
Sony Xplod XM-475GSX Multi Channel Amplifier (4 channel amp)
800 WATTS PEAK
- 75 watts RMS x 4 at 4 ohms
- 100 watts x 4 at 2 ohms
- 200 watts x 2 in bridged mode
- 2-, 3-, 4-channel or Tri-Way output
- MOSFET power supply and output stages
The pulse power supply regulates fluctuating voltage from the car’s battery to keep the output power of the amplifier from fluctuating with the input voltage; this results in consistent power delivery despite input voltage fluctuations. - Crossovers
There are separate crossovers for the front and rear channels. Each crossover is variable from 50-300Hz, and can be set for high-pass or low-pass operation. If you need full range output, the crossover(s) may be turned off. The crossovers have a slope of 12dB/octave. - Preamp- and speaker-level inputs – allow easy hookup to any system.
- Gold-plated connectors
- Bass Boost: Bass response may be boosted from 0 to +10dB for frequencies around 40Hz; there are separate low boost level controls for the front and rear channels.
- Requires 8-gauge power and ground leads wiring and hardware not included with amplifier
- Test Tone: The amplifier includes a built-in oscillator that can be activated to check system performance
