Lots of 99-04 mustang parts.
Here is a list of parts I have left from a car I am parting out. It was an 04 Ford Mustang 4.6L V8 Convertible with 40,000 miles on it. If you are looking for something specific check the below list. If its not on the list I no longer have it. Thank you for looking.
1.Convertible top motor.
2. Fuel Rails
3.Fuel injectors
4.Coil Packs
5.Left Side Skirt - Silver ( 2 very small marks on it)
6.Right Side Skirt - Silver ( perfect shape)
7.Trunk without Spoiler, latch, key lock, struts, badges (perfect) - Silver
8.Windshield Seal
9.Trunk Seal
10.Complete Interior of truck with hardware
11.Right Rear window, track, motor, wiring etc assembled
12.Airbag Control Unit (under dash)
13.Throttle cable with bracket and hardware
14.2 rear seat latch, hold downs, with hardware
15.Trunk latch with hardware
16.Inertia switch (in trunk left side Black with Red button)
17.Complete cruise control unit with cable and all hardware
18.RR seatbelt with Hardware
19.LR seatbelt with Hardware
20.Windshield wiper motor with hardware
21.Headlight Switch
22.Starter with red plastic cap/cover
23.Tensioner pulley with bolt
24.Power steering reservoir with bracket
25.2 horns with bracket and hardware
26.Fuel Pump driver module with bracket and hardware
27.Windshield washer fluid reservoir, pump, line and hardware
28.Main wiring harness off the ECU
29.Trunk wiring harness with light bulbs
30.Complete inside of car wiring harness with under dash everything runs down drivers side of car and across car also feeds trunk
31.Under hood fuse box and harness that crosses over radiator support
32.Battery to starter harness
33.Upper engine harness (full injectors etc)
34.Stock air box
35.Stock MAF
36.Coolant overflow tank
37.R Stock exhaust Manifold
38.L Stock exhaust Manifold
39.OEM Ford Alternator, Bracket, and all hardware
40.Complete Steering Rack with inner and outer tie rods all in, bushing and hardware
41.Front sway bar with bushings, mounts, and hardware
42.Sub frame connectors (stock)
43.16’ Spare wheel and tire (used once)
44.Brace (connector ) under oil pan connects each side for front of car
45.Left Strut, A-ARM-sway bar end link, ball joint
46. Right Strut,A- ARM-sway bar end link, ball joint
47.OEM Injectors (8)
48.OEM Fuel Rails
49.OEM Coil Packs (8)
50.Upper Intake OEM
51.Throttle Body OEM
52.Blower Motor
53.Brake Booster Assembly
54.Convertible top motor
55. L outside painted silver pillar piece
56.Complete Steering Column with Blinker lever, clock spring, Wiring and Hardware, Seal and Bearing
57.Steering Cylinder Lock, Key Assembly with key
58.Driver side door switch panel
59.Heater Controls in dash
60.Front seat belts
61.Every single wiring harness, fuse box and piece of wiring from the whole car.
62.Rear view mirror (convertible) with lights in perfect condition
63.40th anniversary fender badges
64.40th anniversary automatic petal assembly
65.Complete fuel tank assebbly, pump, sending unit, wiring, ect, etc…
LET ME KNOW IF YOU ARE INTERESTED IN ANYTHING VIA Message WITH AN OFFER… BE REAL WITH YOUR OFFER!!! I may be interested in trading for some Foxbody parts, 4’ light ballasts for my garage, oxygen, acetylene tanks, .223 ammo, or anything else worth my while.
i can send pictures of any specific part youd like to see. If you have any questions at all please message me anytime.
