I’m selling a bunch of parts from a build that I never completed. Ran out of time and money. Pics will be up soon, I have to find the cord for my camera to upload the pictures. I can send cell pictures on request if needed.
I know i missed some things, Ill add them over time as I sift through more of it. As far as price, start off by making offers or pm me the parts you are interested in and we’ll discuss price. The more you buy ill take that into consideration when determining price.
Block
B18A1(PR4), bored .30 over, balanced to 10,000rpms
RS Machine PR3 Pistons
Shotpeened, honed OEM ls rods
OEM B16 Oil Pickup
OEM B16 Windage tray
Moroso Aluminum race oil pan
OEM CTR N1 Crank Pulley
OEM ITR Oil Pump
OEM ITR Water Pump
ITR Belt tensioner
Golden Eagle LS/Vtec kit
ACL Main Bearings
ACL Rod Bearings
ARP Rod bolts
ARP Main bolts
OEM Thermostat Switch
Hastings Piston Rings
The head itself and the VS/retainers have about 10,000. Cams less than 3,000. Everything else is brand new.
Head
ITR, Stage 3 P&P, # Angle Valve Job, Decked .10
Supertech Flat-top valves
Rocket Motorsports Gen 1 Dual Valve Springs
Rocket Motorsports Titatnium Retainers
Skunk 2 Tuner Series Cam gears
Skunk 2 Pro 2 Cams
Skunk 2 Portmatched 1 Gen Intake Manifold
Edelbrock 70mm 1/2" TB spacer
P2R TB gasket
Edelbrock Portmatched 70mm TB
AEM 3" Custom Aluminum CAI
BPI 3" Flow Stack
K&N 3" Highflow filter
ARP Headstuds
King Motorsports Extended Intake Manifold Studs
King Motorsports Extended Exhaust Manifold Studs
Cometic MLS head gasket 81.5mm bore
Hondata IM gasket
Shaved and painted valve cover.
Fuel and Ignition
Walbro 255lph fuel pump
Aeromotive Fuel Rail(NEW)
Aeromotive FPR
RC Engineering 400cc Injectors w/ clips(NEW)
Rywire OBD1 Dizzy
Magnecor 9mm wires(NEW)
Innovative Wideband
Cooling
Koyo Radiator
Koyo 1.3 Bar cap
Innovative radiator mount
Transmission
JDM s80 tranny
stock lsd
ATS 4.9 Final Drive
B&M race short shifter
Hasport shift linkage
Action 1 MD 6 puck clutch
ACT streetlight 12lb flywheel
ARP clutch bolts
ARP Flywheel Bolts
MISC
SSBC big brake kit; 2 piston calipers, with rotors. no lines, unknown pads.
KTeller 3" custom exhaust
HKS ti-max muffler
Corbeau FX1 Pro Seats
Corbeau 3" 5pt competition harnesses
Corbeau seat rails, fits 88 crx si but i dont know what other chassis
ITR intake valves
Hasport engine mounts
Autopower 4pt rollbar
