I got a few things i wana clear out and see if there is any Intrest, Pics will be up soon for each thing if they are not already up!..
Megan Track Coilovers - 800$
Not sure total K’s looks perfect and rides perfect i used them for a season and bought them off LucidSnow here on SON…
Pics to come!
Winter Tires: 200$
The tires are
2x 205/60/15 Magna Star Tires
2x 195/60/15 Kingstar tires
Bought them off RR32GTRR here on son, There is one problem with one of the 4 tires IT PREGNAT but it on the inside of the rim i was going use them for winter with the baluge but my SOHC is giving some problems so im storing it for a swap or something… so that why im selling the winters. here a pic from orginal thread
White 17" 4 lug Rims w/ NO TIRES : 350$
offset: +38
pattern: 4x114.3
180sx type X VLSD with 5bolt axles : 220$ TW/ open diff + cash
I have an ABS S13 with VLSD, I’m starting to develop some backlash in the diff, chatters when going from a stop. Will I be able to use the non-ABS VLSD that you’re selling? If not, what would be required to make it fit, a non-ABS driveshaft?
The difference in length of the drive shaft is 1/4 inch roughly
I wouldn’t advise running the incorrect drive shaft but if push came to shuv it will work
Fyi i have a non abs drive shaft that i spent a hour cleaning and polishing then painting before i bought the VLSD which turned out to be ABS. What a pain it was to find a ABS shaft to correspond with the new diff. $50 and my non abs black driveshafts yours. You’ll make your money back off your abs shaft when some one in need of one comes along as they are hard to come across.
