Megan Racing Track Series Coilover Damper Kit
The new Track-Series of suspension surely stands out above the rest with the dependability and performance that Megan Racing suspension products are known for. With a gunmetal finish and coated springs for durability, the Megan Racing Track-Series dampers obviously mean business at first appearance.
The increased spring rates, stiffer shock setting and heavy-duty piston construction all add up to a suspension system that outperforms most suspensions that retail for almost twice the price.
Set as an option for those who demand higher spring rates the adjustability is similar to that of our Street-Series Damper Kits. The ride height, camber and spring pre-load capabilities remain the same and maintain the ease of adjustment as before.
Available for S13/S14/S2000
Spring Rates: 12kg Front and 10kg Rear
32 Levels of Adjustable Damper Strength
Pillow Ball Upper Mounts w/ Camber Adjustment.
Rubber Dust Covers.
Wide-Range Adjustable Ride Height
Competition Spring Rates
Single-Cyliner Design
Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
All coilover damper kits come with 1 year manufacture-defect warranty.
All Hardware is Included
-$1249 cdn
BattleEndless Performance
2 - 99 Select Ave.
Scar. ON
M1V 4A8
www.beperformance.com
Tel: 416-272-2821/416-561-3711
Fax: 416-609-3026
sales@battleendless.com
