Mostly S13 suspension parts plus more!
-D-Max Super street Coilovers for S13 used for 200km SOLD
-[SIZE=1]Bings 5[SIZE=1]mm 4/5 lug slip on spacer (only a pair) [SIZE=1]$25[/SIZE][/SIZE]
-S13 SPL RUCA $250
[/SIZE][FONT=arial black][SIZE=1][SIZE=1][SIZE=1][SIZE=1]-S13 Isis tension, toe, traction arm all together SOLD[/SIZE][/SIZE][/SIZE]
-D-Max clear side marker $40
-Reinforced, blasted, powdercoated black s13 non hicas subframe with spl aluminum bushings will come with RLCA $250[/FONT][/SIZE]
-Weld[SIZE=1]ed diff SOLD[/SIZE]
-Tomei shift knob $50
[SIZE=1]-[SIZE=1]S13 door cards and glove box wrapped in bride fabric $150
[/SIZE]-S13 LHD D-Max floor mats Black[SIZE=1]/Grey [SIZE=1]SOLD
-[/SIZE][/SIZE][/SIZE][SIZE=1]S13 Tein Inner & Outer Tie Rods[/SIZE] SOLD
-Custom S13 FLCA’s, extended 1 inch for more camber
S14 ball joint
reinforced underneath
custom adjustable heim joint for solid bushing
powdercoated black
25mm longer than stock S13 arms and 10mm longer than stock S14 arms, the heim provides even more adjustability (i ran -10.5 degrees no problem) $350
-ICHIBA Extended Wheel Stud 50mm 12x1.25 and Muteki Black Open Spline Drive Lug Nuts 12x1.25 $80
-DIF [SIZE=1]Stainless Steel braided Front Brake[SIZE=1] lines[SIZE=1] for stock [SIZE=1]or Q45 and Isis Stai[SIZE=1]nless steel braided rear lines [SIZE=1]$60
-180sx 4 lug brakes[SIZE=1] fresh calipers[SIZE=1], hawk pad, brembo blank rotor with front and rear knuck[SIZE=1]le, mint wheel bearings[SIZE=1], SOLD[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE]
-Buddy Club Super Low Down Seat Rails[/SIZE] $100
-Zg Flares fiberglass black (2.5" wide rear, 2.25" front) $125
-I have some interior pieces as well in good condition, text with questionsand for pictures
text 9059787491
Bump
SOLD
‘Sold’ as in everything?
alll sold
