Started new for sale thread… hopefully i will keep up with this one. adding more later.
You guys can hit me up on here, or tyler@grafikzim.com,
or call Tyler @ 330-340-9546 leave a message and number if you get my voicemail and I’ll try to get back to you asap, I work most days until about7.
Make me offers on this stuff, school loans + car electronics installers wage = no $$$
dont hesitate to ask if you want something let me know we will work something out.
Tokico shocks and struts still good working condition, i just wanted stiffer suspension. will fit 92-95 civics, 94-00 integras, all del sols
$50
MSD pro cap for b series dizzy with wire to external coil, ran for about 2000miles then went back to stock ignition (i do not have the msd rotor)
$35
2 msd blaster ss coils one ran for 2,000 miles, the other for about 15,000 miles
both in great working condition
$30 for the newer
$20 for the older
MSD 6AL ignition controller with rev limiter rpm modules up to 8200rpm, was run for about 2000 miles, perfect working condition, went back to stock. All manuals, stickers, wires, guides, box, connectors, everything that came with it packaged like new back in box. THIS UNIT IS LIKE NEW!
$180 ($220 new)
MSD sci ignition controller, DOES NOT WORK, I have no idea what is wrong with it, I took it of my car and it was working fine, hooked it back up and it didn’t work, maybe something simple inside, I did not open it up, maybe someone knows how to fix these
$30
This is a inline fuel pump from a drag turbo kit, I never used it, but It was used before I got it, I hooked it up and pumped fuel through it, it works perfect.
$40
Blox 12:1 fuel management unit (FMU) perfect working condition comes with mounting bracket.
$50
Blox map bypass valve for Honda b series perfect working unit
$20
DSM turbo timer harness,came off of a 2nd gen eclipse
$10
del sol custom fit sub enclosure for 2 12’ subs, NO SUBS INCLUDED
$80
outer steering rack tie rod end brand new for 91-93 integra right side
$10
2 feet of both –6an and –10an stainless braded line, Earls brand new never used also have a never used –4an to 1/8 ntp adaptor, it’s Russell
$20 for the –10an
$10 for the –6an
$2 for the adaptor
arospeed black wing, single deck now, I made new endplates for it to tone it down a bit, it’s a satin black finish, and comes with all hardware.
$70
Buddy Club rear del sol bumper milando red fiberglass
$100
Agressor Sideskirts del sol fiberglass milano red
$20
B and D series AC lines, compressors, condensors
let me know what you need, i’ll see if i have it.
