I screwed up the timing on my car and blew the rings outta it, and i think it will be cheaper to put a used motor in than rebuild mine, i ne3ed it running by monday so i need a motor like yesterday. i see a few people have some forsale but no replies, give me a call at 716 796 7575 and i will talk need to be in perfect running condition, no dissasembled sh*t, like i said i will come pick it up today. thanks
you can take my whole car for 800 151*** on motor
We have at least one, call 519-242-3965 his name is brendan. I assume You need a KA24DE?
If u pick up a high km motor theres a good chance ur going to making this same post in a few months.
Call up multisync and see if his low km ka is available … i compression tested it myself and it hit 200 psi on all cylinders.
or better still rebuild
I have a lower km (approx 160) on a sohc engine. Someone is supposed to be picking it up on saturday. If they end up bailing out i’ll let you know on saturday. You can take it for $40. It is missing the master and slave, ecu, and has a cut harness.
200psi!!!
WOW thats one HELL of a motor!!!
:rolleyes:
i called him and he said he has found one locally.
got one thanks guys
stevo, you doing the swap tommarow at your shop?
yeah its commin out as we speak matty, i got two motors and two trannys and another car. jesus this is an addiction. stop by if you want…
