SAMSUNG TX-S3084WH SlimFit 30" Widescreen HDTV TV
Just found one of these for sale wondering if you think its good or not… info
2 auto sensing wideband Component Video Input
2 HDMI input
20 watt built-in speakers
Built in ATSC/ NTSC tuner which processes 1080i/ 480p/ 480i signals
3:2 Pulldown
Color temperature adjustments
True compatibility with Progressive Scan
Display
Screen Size (Diagonal) 30"
Aspect Ratio 16:9
Picture Tube Fine Pixel Dot Pitch Flat CRT
Lines of Resolution Not Specified by Manufacturer
Comb Filter Not Specified by Manufacturer
Video
Video System NTSC
HDTV Compatibility Yes
TV Scan Lines SDTV - 480i
EDTV - 480p
HDTV - 720p, 1080i
TV Tuner NTSC (Standard analog broadcasts)
CableCARD Slot No
Speaker
Sound MTS-SAP Stereo Sound
BBE high-definition sound processing
Power 10 watts x2 (20 watts total)
Orientation Vertical
Input/Output Connectors
Inputs HDMI - x2
RF Coaxial (Antenna) - x2
Composite AV - RCA x4 (1 Side, 3 Rear, two of which are shared with component inputs)
S-Video - x2 (1 Side, 1 Rear)
Auto-Sensing Component (Y, Pb, Pr) - RCA x2
Outputs Composite AV - RCA x1
Digital Audio (Optical) x1
Control Port No
Convenience
Picture in Picture (PIP) No
Digital Media Slot No
Menu Language English, Spanish or French
Remote Control Universal, controls up to 4 components.
Power
Power Requirements AC 120V, 60 Hz
Power Consumption 180 W
Energy Star Compliant No
General
Dimensions (WxHxD) 35.8 x 22.4 x 16.3" (910 x 570 x 415mm)
Weight 117.2 lbs (53.2kg)
I just bought a 42" DLP Samsung 2 months ago. DLP HD. Love it. No t.t.t.rails.
