NEW Polk Speakers 6.5" 2-Way Component System with External Crossover
BRAND NEW IN ORIGINAL BOX
$150
Features
2-way design: The Polk db6501 has both a polymer/mica composite woofer with rubber surround for the low sounds and a silk/polymer composite dome tweeter for the highs.
Max power: This 6.5” speaker brings out the best in your car’s audio system with 300W peak power and a 35Hz–23kHz frequency response.
Marine certified: Polk db series speakers are marine certified and built tough to withstand hard-hitting environments, so they are perfect for use in boats of all types.
Built to last: A pole-plate heat sink promotes better heat dissipation for superior power handling and reliability. Additionally, this speaker contains a flat spider grill with sewn-in, flexible leads for faster, longer excursion linear motion.
Easy installation: The db6501 boasts a multi-hole mounting pattern and shallow depth for easy drop-in installations for practically any car on the road—including yours. Plus, supplied adaptor rings enable the system to fit both 6.5” and 6.75” applications.
Power
RMS Power Handling (watts) 100
Frequency Response (Khz) 35hz-23khz
Peak Power Handling (watts) 300
http://www.circuitcity.com/IMAGE/product/detail/plk/PC.PLK.DB6501.CN.JPG
sellers gay :banana
