We’ve been busting out new parts left and right already! 2015 has been good so far!
The fittings and lines are a little different between the metal valve cover and the plastic ones, so make sure you’re getting the right one if you’re purchasing.
This will mount to the lower radiator support and has easy drain access. Includes everything to bolt on and install.
I’ll have installed photos up soon!
The STM Engine Oil Catch Can for the Evo X metal valve cover includes everything you will need for a direct install. Our kit places the can neatly out of the way on the lower radiator support, also allowing easy drain access from under the car. The aluminum body is fully fabricated in-house and comes in the standard aluminum finish or a mirror polish.
Includes two K&N breather filters and high quality Russell fittings with the lightweight ProClassic line that is super easy to work with and doesn’t scratch your car! A soft buffer is stationed on the underbelly of the can for stability and to help prevent scratches. STM Valve Cover Fittings are included.
- Tig Welded Aluminum Body
- High quality -AN Fittings
- Lightweight ProClassic Line
- Brass Drain Fitting
- Valve Cover Fittings
- K&N Breather Filters
- Install Hardware
- Made in the USA
STM Metal Valve Cover Set-Up:
STM Plastic Valve Cover Set-Up:
That’s the standard un-polished finish. I’ll update with a polished can soon also.
Priced at $450 unpolished, $500 polished + $6 shipping to the lower 48 states.
Find them here:
www.stmtuned.com
