Hey Son member we are selling this coupe we have, reason for selling is the charging system stop working,car will need alittle electrical work that’s about it, here are some parts on the car
-SR20 redtop-s14T28 with braided lines-new spark plugs
-JimWolfeTechnologies Chipped ecu.740cc injectors,z32 maf
-Wiring specialties harness 2 seasons old
-Stage 3 clutch 50%life(works great)5speed transmission has zero issues aswell
-Greddy FMIC with TurboSmart BOV
-3" apexi N1 dual tip,high flow cat and downpipe also
-mishimoto rad/fans but would be replaced with stock SR-Rad-Shroud-Fan assembly
-Full rear Bings multilink-Meagan Front components aswell
-Solid aluminum subframe bushings-VLSD rear end
-Hydro Ebrake
-Tein Flex coilover,1-2 seasons old with full ajustable dampening
-xxr 527 17"-9 3/4" wide with -25 offset, front has bings 10mm spacers.ext.studs, alum lugs
-OMP steering wheel with hub assembly not quick release just bolt on
-tan leather interior,Tomei shift knob,boost gauge
-proper alighnment done.set.and not tampered with
Things to know about the car
-charging system down but car can be heard running
- floor needs to be repaired in near future
-we safetied this car from a friend this summer,also had a Etest done with SR and it passed, car is now registered with driveclean as hotrod etest
$3500 is the bottom dollar and we could add some random parts to “better the deal” that’s about it first come first serve, text 289-983-5246 for pics and more info, no flakers or lowballers
