Non ABS Engine bay brake lines
FS OEM non ABS brake lines located in the engine bay:
  1. left side -short line from m/c to caliper
  2. right side-long line from m/c to caliper
  3. rear brake line from m/c to junction block on the right side @frame rail
These appear to have been replaced with new OEM lines as there is very little corrosion -all the fittings are good---perfect for a ABS delete project with an OEM look
$75. PM your contact info if interested
SOLD
