Paging unix nerds, need help with mass file extension change
I have about 400 .htm files that I need to change to .html. There is absolutely no way that I am going to do this by hand. Does anyone know of any unix commands that would allow me to do this. I assume it’s in the realm of regular expressions.
I tried my luck and went with:
mv *.htm *.html
That did not work!
Let me know what would be my best bet. Thanks!
–mark
ugh, I know there is a way but I’m not remembering it, hold on
edit:
after a quick google search and a quick test
ls -d .htm | sed 's/(.).htm$/mv “&” “\1.html”/’ | sh
simpler option:
for i in * ; do mv “$i” basename "$i" .htm.html ; done
for i in *.htm;
do mv $i ${i%%.htm}.html;
done
You sir, are the man!
Thank you much!
<EDIT> Problem solved I guess
