PLEASE PM ME WITH YOUR ZIP CODE AND THE PART YOU WANT and I will be able to reply with the total cost with shipping. I will try to stay current on the threads, but whenever someone replies that they want something it goes to pm anyway so it’s easier to keep track of all pm’s.
I priced everything relatively low, let me know if anything is off base. There are a few things that don’t have a price listed, pm me with what you’d like to pay (within reason, don’t lowball please).
paypal is magnanimousmotorwerks@gmail.com
1998 silver exterior black interior 136xxx miles
s50:
complete head w/cams, trays, valves, vanos, valve cover, etc. 124k miles. $600 sold
timing cover $40
pistons $150 sold
rods $120
crank, needs machining $50
block, needs machining (main bearings would need to be bored and oversized bearings installed) $50
oil pump $50
windage tray
alternator $50
power steering pump $30
crank pulley $40
starter $40
valve cover & plastic $50 sold
s52:
exhaust manifolds $90
secondary air pump (will sell complete system) $90
intake manifold $50
wiring harness $120
knock sensors $35 each
oil filter housing $75
mass air flow sensor $50
traction control actuator
throttle body $45
heater core
heater control valve $30 sold
air box $75
throttle body elbow $15
o2 sensors $35 each
coil packs $70
injectors and fuel rail $80
icv $40
zf trans $390
aux fan $40 sold
radiator w/overflow tank and shroud $50
brake booster $40
brake master cyl $50
fuse box $40
abs pump $50
a/c compressor $40 sold
a/c condenser $40
wiper arms $40
wiper motor $30
wiper linkage sold
hood insulation $30
factory alarm siren pn 82111469447 $30
windshield washer fluid reservoir and pump $30
brake fluid reservoir $25
brake calipers $100 front $100 rear
sway bars (have surface rust) $20 front $20 rear
halfshaft (only have one) $20
3.23 lsd $350 sold
trans crossbrace $15
sunroof motor $40
pedal box (could make a whole manual trans swap kit if desired)
fog lights (look possibly aftermarket) $20
cd changer w/cartridge $75
trunk carpet $40
trunk side panels $40
trink lid carpet
complete tool kit $20
trunk lid struts $20
door sills $115
mirrors $125 sold
sideskirts $125 sold
dash $80
glove box $60
power heated vaders $500
rear seat $125
front door panels $150 each
rear door panels $50 each
gauge cluster (~130k) $100 sold
digital climate control $60 sold
center console w/armrest $50 sold
headunit $70
black headliner $150
a,b,c pillars $60
shift boot
ebrake boot & leather handle
black carpet
floor mats $50
shift surround $40
steering wheel airbag $60
map light $50
parcel shelf
side molding; only have for the doors
doors, each has a small rust spot illustrated in pics. $75 each
window regulators & motors $60 per side
window glass, rear glass
m3 spoiler (trunk lid is bent wing looks ok) sold
HK door mids $40 sold
HK door tweeters $30 sold
HK drivers (kick panel speakers)
HK rear speakers sold
front seat belts $45 sold
motorsport shock tower covers
drivers side fender. may have been sprayed to blend at some point, will check if it has a vin on it.
headlights, glass lens. pass side has a couple broken tabs, drivers side good
Monday 11/15/10 thread has been updated and all pm’s replied to. If you have an inquiry that I have not replied to I apologize, please pm me again; it’s tough keeping track of everything
The whole int would need to be swapped. LAZY!!!
