All part prices are local pickup. I will ship at the buyer’s expense. Located in North Buffalo, NY, 14216.
I’d be happy to answer any questions you may have about parts condition, history, etc. Shoot me a text or call at 716.949.7424. You can also reach me by email (nogiba5@gmail.com) or via PM.
I am open to offers and negotiation within reason on all parts.
BMW parts first.
Thule Roof Rack/Ski/Snowboard Attachment (THULE 753). comes with anti-theft bolts and allen wrench, and locks/keys. Base rails are tentatively spoken for. $150 for top rack.
BMW E39 540I V8 Open Differential. 2.81 ratio. No issues, works perfectly.
$150
also have a BMW E39 V8 3.15 Ratio “Sport” open differential for sale. No pictures because it’s still on the car. Works awesome. $275
BMW E39 M62 NON VANOS INTAKE ELBOW/THROTTLE BODY
This came on an intake manifold I bought, I have no use for it.
$40
BMW E39 540i V8 BOSCH Mass Airflow Sensor. Bought it new thinking it would solve an issue I was having, turned out not the MAF was not the issue. Ran it literally around the block and removed it. OEM Bosch.
$75
BMW 540i 6 speed trans (Getrag 420G), shifts perfectly. The grease stain on it is from a leaking valve cover gasket when it was in the car. The transmission does not leak whatsoever.
$700
BMW 540i 6 speed clutch and pressure plate. Worked perfectly when pulled from car.
$100
Plenty of life left in the clutch.
BMW 540i 6 speed OEM dual mass flywheel. No problems when pulled.
$100
BMW E39 V8 6 speed Transmission crossmember.
$50
If you’re interested in the entire 6 speed swap for your E39/E38, I can give you a better deal on the whole package: trans, clutch, pressure plate, flywheel, crossmember, shifter.
BMW E39 540i 6 speed shifter
$20
BMW 6 speed ///M Shift Knob. Like new condition, used for 5k miles.
$50
BMW M62 V8 intake vacuum pipe
make an offer.
BMW E39 M62 Intake tube. will separate from MAF. MAF is OEM Bosch, no problems.
$20 for intake elbow
$75 for MAF
BMW E39 M62 Fan Clutch/Fan, OEM. No problems. Good to have as a spare in case yours decides to leave the engine at 70mph.
$ make an offer.
BMW M62 V8 Engine Cover Brackets
$ make an offer.
BMW M62 Starter, no problems, worked perfectly when pulled.
$100
BMW E39 540i M62 V8 Rear Oxygen sensors (L/R)
$40 each
No issues, worked great, no stripped threads. I also have the front sensors for sale.
BMW E39 M62 Oil Filter Housing
$50
BMW M62 V8 Engine Harness/Fuel Rail/Injectors/misc connectors
$150 for everything OBO. not sure what it’s worth.
GM Parts now.
All engine parts from a 2003 Chevy Express Van with 134K, 6.0 LQ4 Application.
LQ4 “Truck Intake”. Comes with fuel rail, injectors, throttle body, etc etc.
$150
$25
LQ4 Tensioner Bracket
LQ4 Van Air Cleaner. I am keeping the MAF for my swap.
$10
LQ4 6.0 Crank Pulley
$ make offer
Van Intake Tube
$ make offer
LQ4 Van Oil Filler Extension Tube w/ bracket
$ make offer
LQ4 Van AC Compressor
$50
LQ4 Van Power Steering Pump w/ lines
$50
LQ4 Van/Truck Water Pump
$50
317 Head bracket
make offer
317 Head bracket
make offer
LS Motor Mount. Originally Van mounts, I modified them thinking they might work for me. No dice. You could use these as a start of custom mounts.
$20
LQ4 Truck/Van oil pan. includes baffle, pan, and pickup tube.
$50
LQ4 Truck 6.0 Automatic Flexplate and Crank Spacer
$30
LQ4 Oil Cooler lines, rough shape
make offer, maybe someone can use the fittings?
LS1 Camaro Oil Pan. Comes with baffle, pan, and pickup tube. No problems, just doesn’t fit my swap.
$125 firm
LS1 T56 Mounting crossmember.
$50
