If any of you wankers are trying to go fast on a glide/ls setup figured I would post here. This converter is $965 new. I ran it in the Nova to a 9.0 on a stock bottom end 6.0.
Anyhow we thought it was too loose, later found out I had ran the wrong fluid. Should run well into the 8s. This is the same converter stock48 runs bottom 8s on if you are on ls1tech.
Might make a deal for someone local cause im a nice guy like that
