PWM Solenoid Push-Connect Fitting Kit
Bought this and never used it… 30 shipped obo
This is the perfect solution for someone wanting to cleanly install a PWM Boost solenoid without a mess of rubber line and barbed fittings. This kit includes the fittings necessary for a standard (single) external wastegate install along with a length of polypropylene tubing to connect it all.
The tubing included in this kit has a tensile strength of 4700psi, and a max temperature of 200 degrees Fahrenheit. The tubing has an OD of 1/4" with an ID of 1/8".
Included in this kit are the following components:
  • (5) 90 degree nylon/nickel-plated brass swivel push-connect fittings (1/8" NPT)
  • (1) Nylon push-connect tee - (1) 10ft length of tubing (additional tubing can be added using the drop-down menu above)
39.95 New from -
www.xenocron.com
ttt
$20 shipped
25 shipped
