Hi guy!
I got these parts for my car but I am about to sell the car and no need for these parts,
I have a Delphi 525cc injectors for rb20det (may fit rb26dett)
Home » DELPHI INJECTORS
Product ID: 17113738
DELPHI 50lb/hr INJECTOR
DELPHI 50 LB/HR INJECTORS
Part Number 17113738 (OE # 17104487)
Static Flow Rate: 50.0 lb/hr @ 43.5PSI (300kPa) 525cc/min or 6.4gm/sec
Static Flow Rate: 57.7 lb/hr @ 58.0PSI (400kPa) 606cc/min or 7.4gm/sec
Dynamic Flow Rate: 1.1 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI (300KPa)
Dynamic Flow Rate: 1.3 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 58.0PSI (400KPa)
Coil Resistance: 12 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Cone Spray Angle - 22.4 degrees - Single spray cone. Approximate cone angle for 90% of spray volume
Ball/Seat Design with 6-Hole Diffuser Disc
And I have a set of front gtr brake system: calipers, pads, rotors and brake lines.
I am looking for $350obo for the injectors and $200obo for the gtr brakes.
