Kind of out of the ordinary for son, but worth a shot.
Pajero is now fully for sale if interested
1994 Mitsubishi Pajero L4000 2800 turbo diesel
82,000kms (bought with 63,000)
5 spd (hard to come by) good clutch no slipping
Super Select 4x4 with center diff lock all works flawlessly
4 wheel disc breaks with a new rear caliper
All fluids changed
Ralli-art wheels (rare)
Oil changed every 8000kms with Rotella synthetic and Baldwin filters no cheap stuff
Interior is clean with little wear
Has pioneer display deck that I may keep depends what comes through
Also has new front and rear main seal for injection pump
Has EGR delete kit installed
rebuilt altrenator
Brand new glow plugs and glow plug rail
New primer pump and fuel filter
New battery
DRL module
95% tread left on 31/10.5/15 Hercules trail diggers
Adjustable suspensionall works
Has a bull bar and 2 big yellow fogs
AC BLOWS ICE COLD!
Heater works
And I am sure I am forgetting some more stuff.
has two small dents in the hood and one on the passenger rear plastic piece, plastic can be changed
Thanks guys, Truck is great and has never let me down, just to add, all the problems these trucks are known for have been dealt with so it is a turn key and go truck, the primer pump main seals always dry out and split causing sparatic engine stalls, those have been changes 700$ at RD, altrenator is freshly rebuilt, tires are perfect, brakes were done all around when the truck was bought, and to the buyer, i also have a box of I believe 5 baldwin filters as well that go with the truck to start you off right, back seats recline for uhhhh leisure activites and the heater is blows fire hot and the truck warms up quickly, also has a block heater, the truck avgs 700kms to a fill up depending on driving style, turbo spools nicely and leaks/burns no oil. all 4 glow plugs and rail are new and the glow plug controller functions as it should. It truly is a great truck, but with life taking a different direction I need something better suited to it.
PM is key I respond rather quickly. Thanks for the kind words gents Cheers!
