BRRRR ITS COLD , GETTING COLDER!!!
PRICES AS OF OCTOBER 30 - 2009 limited quantities on some units.
AUTOSTART - AS-1455
This is an entry-level system with high-end functions. Features independent lock and unlock, trunk and start/stop buttons.
Unit Specific Features
* Two miniature 4-button transmitters
* Up to 1200 ft / 370 m of range
* Monopole antenna with embedded red LED
* Ignition controlled valet mode
* Turbo mode
* Idle mode
Unit Specific Options
* Tech tool compatible
* Virtual Tach System (automatic transmission mode only)
* 1 auxiliary output
* Aux. 1: Horn or priority door access
INSTALLED $158.00
CLIFFORD - 4203X RESPONDER ONE -TWO WAY 1 BUT. STARTER
24-channel remote start system, Clone-Safe# & Code-Hopping#, SuperCode 2000# of Range, Programmable Parking Light Flash Output (+ / -), Virtual Tach, Built-in XCR# (Extreme Capacity Relay Satellite), D2D & XpressPort Ready, Built-in Turbo Timer, Horn Honk Output, LED confirmation on Transmitter (comes with 2 - 1 button 2-way transmitters) AUTOMATIC ONLY
MANUAL TRANSMISSION ADD $39.95
INSTALLED $219.00
CLIFFORD - 4102X 1.2X ONE-WAY RESPONDER LE STARTER
24-channel remote start/keyless entry system, Clone-Safe# & Code-Hopping#, SuperCode 2000# of Range, Programmable Parking Light Flash Output (+ / -), Failsafe Starter Kill/Anti Grind/ Defrost Output/, Virtual Tach, Built-in XCR# (Extreme Capacity Relay Satellite), D2D & XpressPort Ready, Built-in Turbo Timer, 4 Auxiliary Outputs, User adjustements & programming done thru the transmitter, Horn Honk Output (comes with 2 - 5 button 1-way transmitters)
INSTALLED $199.00
CLIFFORD - 4202X 1.3X TWO WAY RESPONDER LE STARTER
24-channel remote start/keyless entry system, Clone-Safe# & Code-Hopping#, SuperCode 2000# of Range, 2-way confirmation on transmitter with GhostLight LED’s, Programmable Parking Light Flash Output (+ / -), Failsafe Starter Kill/Anti Grind/ Defrost Output, Virtual Tach, Built-in XCR# (Extreme Capacity Relay Satellite), D2D & XpressPort Ready, Built-in Turbo Timer, 4 Auxiliary Outputs, User adjustements & programming done thru the transmitter, Horn Honk Output (comes with 1 - 5 button 2-way transmitter and 1 -5 button companion transmitter)
INSTALLED $249.00
PLEASE NOTE:
BYPASS MODULES are extra
prices listed above include a basic install of a remote starter only
TRUNK POP/KEYLESS/DEFROST and etc are EXTRA.
all prices are plus taxes.
OUR ELECTRONICS DEPARTMENT operates:
monday to wed: 8am to 6pm
thur 8am to 8pm
friday 8am to 6pm
sat 7am to 3pm
please call at 905 278 2408 for your appointments or questions.
or email us at
krownlakeshore@sympatico.ca
thank you,
KrownLakeshore,
Where friends send their friends,
