i need a RHD z32 tt brake master cylinder.
pm price/pics
pm price/pics
im still lookin for this…
i can do ya one better
ive got a rhd nissan stagea brake cylinder
used as an upgrade in japan on skyline gtr’s. fairlady’s ect ect since its a tad bigger and allows for a little more rear brake attention
its a 15/16th’s cylinder
$50
let me know
matty’s wont work. im still lookin for this guys…
let me know
Contact Kevin@AMS, located in the Vendor section - AMS.
They’re Z32 pros.
I have one. It’s Nabco 15/16" (BM44) with line coming out on the left side.
i need a rhd one, with the lines pointing toward the (jdm) passenger side. i dont wana mess with the oem lines bending them and whatnot.
im still lookin for this. someone’s gotta have one. heres a pic to better clarify what im lookin for
adam`s s13 has one like that as he said comes out left side aka JDM passenger side
So you want it for a NON ABS application right?
ABS = 2 holes
NON ABS - 3 holes
3 hole ones are harder to find as almost all Z’s and GTR came with ABS.
yes, non-abs.
2 lines front, 1 line rear
what raf said ^^^
Not sure about the JDM ones, but the USDM Z32 M/C’s usually came with 3 hole, even if the car was ABS. the one hole was just plugged with a set screw and needed the brake fitting to be cut out of another M/C (any nissan one works) and pushed into the third hole.
Anyone confirm if JDM ones are like this too?
jdm z32s only have 2 holes, while the north american ones have 3 holes with 1 plugged since zs are abs
i have a jdm 15/16 man, think it works, i’ll bring it with me to the shop next time remind me…
ps ask on gtr canada if your not already there should be some there, same size brakes as a z32 on a gts-t…
This is the one I have - Nabco (BM44) 15/16" bore (same as z32) with line coming out on the left side.This is great for turbo and exhaust clearance
I have a JDM 15/16 one I was Playing around with years ago.
I started to drill out the third hole. This was back in day when I did not have ABS.
If you want to finish what I started, send me a Pm and we can arrange something.
To Recap what I’m talking about - JDM z32 15/16 made by TOKICO with 3rd hole started for non ABS applications.
we’ll see if ted’s works,
if not i’ll just have to tee the lines for the front (kinda rafty but it’ll work) or use a LHD bmc and make up some custom lines.
thanks for the interest/help guys
You could also check to see if a dodge stealth (USDM) one will work as it’s outlets are on the left side (like JDM)
They are also made by tokico and are 15/16
ill let you know in the next couple days if my buddy will let go of his.
