Contracted Spy axe,
Ran Spy bot S&D and adaware SE in safe mode about to run CCleaner
Hasnt seemed to get rid of it yet
help
Contracted Spy axe,
help
Try Counter Spy. http://www.sunbelt-software.com I use it and haven’t had a problem yet.
Got it
None of the spyware soft ware did a thing
My cob job fix…
Looked in C:\Windows\system32 for any files modified recently
I knew the problem happened the last time i used my computer and knew i hadnt installed any new programs today.
Found a few files created last night
Couldnt delete at first because they were being used by the virus
Files suspect
svchosts.dll NOTICE THE EXTRA “s”
mssearchnet or something to that effect
and a couple others
the svchosts.dll is the suspect program
renamed the files to something arbitrary, asdfasd and such
restarted the computer and the virus couldnt start because it cant find the files it needs
now they were able to be deleted
restarted again and no errors and no virus
hope this thread helps anyone else in the future
Glad you got it fixed.
Check your registry for these too:
HKLM…\Run: [WildTangent CDA] “C:\Program Files\WildTangent\Apps\CDA\GameDrvr.exe” /startup “C:\Program Files\WildTangent\Apps\CDA\cdaEngine0500.dll”
HKLM…\Run: [SpyAxe] C:\Program Files\SpyAxe\spyaxe.exe /h
HKCU…\Run: [Weather] C:\Program Files\AWS\WeatherBug\Weather.exe 1
Extra button: WeatherBug - {AF6CABAB-61F9-4f12-A198-B7D41EF1CB52} - C:\Program Files\AWS\WeatherBug\Weather.exe (HKCU)
DPF: {288C5F13-7E52-4ADA-A32E-F5BF9D125F99} (CR64Loader Object) - http://www.miniclip.com/supergerball/miniclipGameLoader.dll
Find and delete these files:
C:\Program Files\AWS\WeatherBug\Weather.exe (also folder AWS)
C:\Program Files\SpyAxe\spyaxe.exe (also folder SpyAxe)
C:\WINDOWS\system32\hp6040.tmp
