- Rywire OBD0 to OBD1 ECU jumper harness equipped with both wires needed to wire up Vtec in a non Vtec chassis harness as well as a plug and play setup for a 4 wire o2 sensor. This harness is $100 brand new and I never used it.
$60 FIRM.
- HASPORT B series cable to hydro conversion. Was all scratchy looking when I got it so I sandblasted it to get all of the scratches out and to make it look less blingy. I also replaced all of the bearings in it (ordered through hasport) to make it like new. After replacing the bearings I used it for about 6xxx miles. I no longer need this because I am putting a clutch master in my crx instead of using a cable.
Looking to get $90.
I will have pictures of this in the next couple days.
- OBD1 LS dizzy
Best Reasonable Offer
