Parts located in Ottawa, On. I will be at Shannonville Monday the 6th if you want to meet up there.
PM or text me (TEXT ONLY, don’t call) @ 613-304-0509.
Drift Freaq poly sr/ka mounts, exhaust side is heat wrapped. New, only mounted - 80$
Audiobahn subs (2x 10"), Sony Xplod 800W amp, custom sub box - 150$
Sard rad for sr20, s13/s14/s15 - 250$
These retail for so much more!
Apexi GT sport for s13 - 250$
Bully stage 2 clutch and machined flywheel for sr20. Only installed and never used. (Motor it was installed on never ran) - 400$
S13 front strut bar made by SPATS - 60$
OEM Nissan KA24DE head gasket part #11042-53F25 - 40$
SR20 Transmission Bellhousing (Swap this with a KA bellhousing to use a KA tranny on an SR) - 80$
s13 manual shifter bezel - 20$
KA-T - 500$
4x SR 370cc injectors
Flanges
Bolts
Gaskets
SS line
KA cast turbo manifold
Master Power turbo - T3/T4 48 Trim Stg 3 .48 A/R - Master Power Part# 810019
Pioneer deh-p2000 - 40$
2008 Mazdaspeed turbo. Little to no shaft play - 200$
I’ve never used it, I don’t know how it runs. Use it to build a custom turbo setup
Another 2008 Mazdaspeed turbo. Lots of shaft play. - 100$
Again, I’ve never used it so I don’t know how it runs.
1996 Nissan Maxima OEM “Honeycomb” wheels wrapped in 15" all-season tires - 200$
5 x 114.3, fits pretty much all Nissan 5 bolt cars.
some faces have seen better days. I would keep them but I can’t run 15"s on my car anymore.
