s13 parts and others
-Nismo 740cc’s. sidefeed. 4 of em. $300
-S13 aftermarket steering wheel hub. unsure of brand, but two separate bolt patterns on it. $40
-Greddy turbo timer. mint used for two weeks. $100 firm.
-s13 harness for tt $10 or both for $105 firm.
-random 180sx interior panels. come rummage through them. cheap cheap. rear carpet, privacy thingy, and seats still kicking.
-greddy boost+temp warning guages. green on white. temp needs a new sensor. aftermarket LEDS inside. bright yo. $240 for em both.
-Greddy sandwhich adapter plate, its a sandwhich plate and that is all. $100
-stock viscous lsd without pumpkin, $donno.
-stock t25+manifold+elbow+lines needs some new studs, and turbo is starting to get leaky seals. $100 ISH offer.
-AC pump/condensor/lines cheap cheap.
in edmonton.
only things im looking for are the
-apexi AVCR EBC
-bride bucket+rail
-takata 4 pt. harness
-s13 silvia CF hood oem/vented
-ss13 silvia widefenders. not too picky on size.
will the 740cc injectors work in an sr20det with a tune. i will be running t28 disco potato fmic 300zx maf walbro fuelpump. i know 740cc might be a little over kill but will it work fine for that setup.
you should just stick to 550’s for your setup.
how long were the 740’s used for?
they are gone a long time ago.
only three things left.
-S13 aftermarket steering wheel hub. unsure of brand, but two separate bolt patterns on it. $50
-misc interior parts
and still need a harness,
