MINT!! S14 Brake master cylinder with a non leaking reservoir and a pig tail for reservoir sensor. It came off a running auto S14 with ABS.
cylinder bore diameter is 15/16 so this is a perfect bmc for you z32 brake swap guys, who still has those weak 7/8 bore BMCs that comes stock in our manual S14s. -------------- $60 -----------------------
Unlocked Rogers BlackBerry 9700 with OS 6
I used this as my primary phone before I upgraded to the 9900.
it has a line of dead pixels along the bottom of the screen. replacement screen is about $20
its a used phone that has a screen protector and a silicone case to protect the backside of the phone. -------------------------------------$60------------------------------------
prices are fair and low sooo…
LOW BALLERS WILL BE IGNORED
PM is key
TXT or call : 647-202-2423
