i need one to complete my manual tranny swap. name your price
I was looking for this as well couple of months ago. But I had no luck.
I ended up going to Nissan and ordering the part. If you want, I can give you the part number as well. It was $175+tax (and that doesn’t include the little gear that goes on top of the sensor. You can jus use your automatic one, it’s the same thing. i.e. same number of teeth and same size).
You do have to give them the VIN of your car. But since your car was automatic and you are buying the sensor for a manual car, they’ll just say that you can’t return it once you buy it.
that would be awsome if you could give me the part #. i have a couple of questions as far how you wired up your 5 speed set up. do you still have a check engine light like i do. and how do i get rid of it. how did you wire the reverse sensor, 5th position, neutral posistion switch etc. thanks for all your help. also how long did it take for you to get the sensor.
im just using my auto ka speed sensor… if not there is a sr speedsensor on my ka tranny soo im going to try that!!
