I have a pillar gauge pod for a s14.
the oil pressure gauge does not have a pressure sensor, so it is pretty much useless other than filling the void in the gauge pod. it lights up as it should but does not read pressure, 10 bucks? (i am not sure if you could use another pressure sensor and make this work properly. i would imagine it wouldnt as im sure there is some sort of calibration for something like this)
the boost gauge works great and is in excellent condition, a must have for all you new sr20 swappers, 60 bucks?
gauge pod is in great condition. the double sided sticky tape that comes with these brand new is shit and never works. i used black zipties and some carefully drilled holes to make this fit solid and remain clean to look at. i am looking to get 30 bucks for this AND your clean, not cracked, clips intact, OEM plastic pillar trim piece. you in return get my whole piece with the gauge pod attached.
reason for sale: i have a digital aem boost gauge now with matching aem air/fuel gauge and a steering column gauge pod. no need for the pillar pods
OR
trade me your oem piece and take this with the boost gauge, gauge pod, and dummy oil pressure gauge + 80
THANK YOU!
