S14/SR Random bits - PS bolts, one way valve
I need the top bolt that goes through the ps pump pulley to the bracket that is mounted to the motor, and the oem nut to cover the high pressure line at the pump. I also need the one way valve above the brake booster and even those hoses would work too. Thanks
Chad
I got it MSG me
