Will be at Shannonville Monday oct 14th for TOPP.
text @ 613-304-0509
Shipping available, located in Ottawa, Ontario (beside Gatineau, Quebec). I also speak french.
Looking for these items if you want to do a trade:
- 1991-1993 Nissan 240sx daytime running lights
- 1989-1993 s13 front seat belts
s13 chuki bumper - 40$
s13 non-hicas subframe. Has surface rust, best if you sand blasted this beauty - 100$
S13 and S14 Stance RUCA’s with about 2km’s on them. Basically brand new! - 200$
S13 VLSD, ABS, 6 bolt output shafts (Is your car non-ABS ? don’t worry. There’s an ABS driveshaft down the list that works with this diff!) - 150$
LHD s13 clutch & brake pedal for a manual conversion - 100$
s13 rear knuckles (non-hicas) - 40$
S13/S14 SARD TCV (Torque Control Valve) it’s been gutted so it’s basically a 3" test pipe now - 100$
S14 Zenki headlights. 1 has broken tabs, the other has humidity in it (left + right set) - 100$
S14 Stance GR+ PRO coilovers, one of the rear bottom sleeves is seized (part that bolts up to the knuckle) but nothing is blown - 800$
S14 zenki JDM cluster - 40$
S13/S14 custom front strut bar, very solid design - 40$
JDM s14 Zenki fenders in good condition - 150$
NO I will not sell the fenders individually
S13 5-speed ABS driveshaft, VERY CLEAN. Has 150 000km on it. It will fit your KA or SR - 60$
S14 crossmember - 100$
OEM Nissan FAT 02 sensor for s13 SR20DET blacktop, only installed, engine never ran - 80$
Part # 22690-50F03
S13 SR20DET blacktop intake manifold - 100$
s13 sr20 exhaust manifold - 100$
s13 sr20 blacktop coilpack harness - 40$
s13 sr20 alternator - 120$
ECU 62 chipped by Almasi Tuning for 550cc injectors and Z32 Maf - 300$
Bought it off a member on here but never used it.
ECU #42 Pulled from a 1993 Nissan 240sx. Automatic transmission with hicas and KA24DE engine. - 40$
S13 climate control pulled from a 1993 hatch. - 40$
[/QUOTE]
