Semi Auto Spyder Xtra Paintball Gun with vertical ball feed,
low pressure chamber, 12" aluminum barrel, deluxe sight rail with
beavertail, bottom line set up with stainless steel hose, super light
trigger pull (mechanical), drop forward, expansion chamber with
fore grip, anti double feed, aluminum 2 finger trigger, quick
disconnect pin, tournament velocity adjuster, rubber contoured grip. -
14oz brass eagle co2 tank which provides around
500 shots when full and complete with pin valve assembly. -
JT NVADER Face Mask, aggressively styled entry level
mask feature the Elite 180° lens, they’re ideal for beginners to
amateurs and offer unparalleled protection and are some of the
safest goggle systems out there for any age or playing level. -
Veiwloader 200 round hopper with extended neck piece.
Veiwloader Care Kit (USED), In the care kit you get,
Oil, Gun Polish, Squeegee and Cleaning Cloth. -
Fokus barrel cover (required at all paintball games).
All the item’s you see below must go ASAP
$120
