I honestly do not want to spend more than 500$.
it needs to run, and have heat.
No fucks given about it passing NYS inspection
buy my neon, its for sale for 800 bux but ill let it go for less than that, its somewhere in thr FS posts
Whats your bottom dollar, i’m looking at a honda later today for 400
id sell mine for that
PMd
i know u said no more than 600 but for 900 i have a 87 325e e30 that has insanely hot heat and will come with good tires i can mount for ya (its off the road)
I have a sweet 98 escort id sell you for 700 obo 5 spd. 75ish k on the clock, timing belt and tensioners done about 7k ago , rear brakes shoes and hardware done, new caliper on passenger side front. Will throw on a new set of front pads for ya. Rear brake lines have been done.
The bad:
Will need a new set of tires.
Not sure if its oil pan or gasket but one or both of those leak a bit (car self rust proofs??)
Small exhaust leak that I never bothered to investigate though the muffler looks holly the car is still pretty quiet for what it is.
Fuel pump is possibly on its way out (no need to drop the tank to replace its accessed from under back seat. )
During the cold the car starts every time at the second turn of the key.
needs a new ebrake cable too.
BUT!! DEspite all that you can still impress your chick with a door mounted imitation carbon fiber switch and under bumper mounted fog lights, and impress your pals with a baler optima spiral cell battery mounted in the engine bay.
At this point you must be crazy to pass up on a deal like this!! But wait! There is more!!! Act now and I will even throw in a shiny shifter knob!!! What, not good enough!!! Then ill even throw in an 8ball themed hacky sack, and a used pair of safety glasses!!!. With all those deals a jewish persian would be tempted. Act now before this offer ends!!!
Got a lumina for 5 beans
