Sohc intake manifold, sohc exsaust manifold, hydro ebrake, 240 steering hub
Pretty much as the title says…
Sohc exsaust manifold
Hydro e break
Steering wheel hub
Sohc Ecu
A full sohc motor would be better, need it for a intake swap on hardbody :slight_smile:
You can text me at 905 922 4144, or leave me a message on here
i have hydro ebrakes in stock.
ISIS L-shaped
i have a isis handbrake and a steering wheel hub and personal wheel. if you still need it. brake will come with everything to install… no flaring you can have the line right from the brake master just screw in and bleed. let me know
i have a hub for you
Ill take the hydro ebrake when can I grab it
ive got a sohc exhaust mani with pipe still attatched past the cat including cat…come get it if u want…I have a bunch of other shit here too if you need it
I have the intake manifold somwhere around here.
Found the parts. Intake manifold. (Both parts) throttle body. Fuel rail. Maybe some injectors but I think they’re shot. Otherwise its all good. Came off my 89.
