SR20 Exedy Clutch And Megan Removable Hub
Brand new hub, installed and then removed, only used for a few days. I put the hub on because i wanted the steering wheel a bit closer but it ended up pushing it out more than I wanted, so im selling it. It is in mint condition and obviously is in perfect working order.
100$ obo
Exedy Step One clutch and flywheel, this is NOT a stock replacement. The clutch has a higher clamping force than stock (im looking for the exact data now). Very nice clutch with tons of surface left on the disk.
200$ obo for clutch disk and pressure plate
Need this stuff gone soon boys
also
s14 SR20DET 380cc (yes 380) injectors with S14 fuel rail
150firm
SR20DET CAS (MINT) $140obo
SR20DET coil packs 40$ obo
Does the removable hub fit directly onto the 240 steering shaft splines? Or does it require an adapter too?
Thanks…Martin.
the megan quick release hub requires the adapter aswell.
yea, it is basically a spacer.
price reductionsss
injectors: 120obo
hub: 80obo
clutch: 160obo
need this stuff gone boys
pm sent.
