SR20 Parts. (MAF, injectors, etc)[preferrably used]
My buddy is buying my sr20 motorset for his coupe and he wants to start buying parts for the swap that he will need.
-some sort of engine management. he wants to get one of those pre-tuned ones off of ebay and I am trying to convince him not to
-550ish top feed
-fuel rail and associated parts
-z32 maf
-swapped harness. I want to just take his and whats left of the sr20 harness (I really thinned it out) and just combine them, he wants to save time and buy one pre-done if its cheap enough.
-rad hoses
Thanks.
why not just keep the stock rail and use sidefeeds?
i can drop ship you some deatschewerks.
can also drop ship some rad hoses and a new MAFS
bc the turbo is pretty big (see pic). idk, thats what i was told should be done.
If side feeds will do it then cool. less expense the better. what about fuel management? best economical way to make decent safe power?
I would throw some 810cc injectors from DeatschWerks and it really matters on you price range for the ems. If you want to do it right spend the $1200 on a aem or haltech. If your on a budget you could get a ecu tune from enthalpy for $350 but you would need every modification that is done to the motor. Hope this helps.
bump. he is in buying mode now, we are swapping in 2-3 weeks.
thinking of going enthalpy for the tune, used stuff preferred for everything else!
get me your buddy’s zip and i’ll get him a quote on drop shipped rad hoses and a new mafs…
buying a used mafs is sketchy, i’ve seen sooo many busted Z32 mafs
