SR20DET Blacktop 180sx Late Model Engine VERY low KM - PERFECT
Hello selling my late model Blacktop s13 sr20det
I have all parts needed as well as aftermarket parts available. Completely drop In ready. Pulled from a chassis with under 60k
Full engine swap
Perfect Compression test @ request.
Engine
5speed MT TRANSMISSION
Engine wiring harness (UNCUT DROP IN READY)
ecu
Intake Manifold
Exhaust Manifold
turbo ZERO SHAFT PLAY
turbo manifold
Injectors
Fuel Rail
Power Steering Pump
A/C Compressor
Alternator
starter
Clutch flywheel pressure plate
$2200, please do NOT contact me unless you are serious. I will ignore all low ballers completely.
CALL / TEXT 289 217 8633
Aftermarket Parts Available for Extra
Below are not included in swap
MISHIMOTO RADIATOR / DUAL ELECTRIC FANS
FULL HKS HI POWER SILENT EXHAUST
Driveshaft NON ABS pulled from 180sx
FULL SIDE STOCK MOUNT INTERCOOLER
3" BRAND NEW IN BOX TURBO ELBOW
BRAND NEW TUBULAR MANIFOLD BOTTOM MOUNT (ISR)
BRAND NEW 3" SAND BLASTED TURBO ELBOW (ISR)
BRAND NEW FUEL PUMP 255 (ISR)
BRAND NEW GASKET KITS FOR ALL THE ABOVE
NARDI WHEEL! WITH UNIVERSAL HUB
