Just thought i would throw this out there since not to many people have the 370z yet but will soon. I’ll edit once i figure out what bolt sizes were what cuz i cant remember off the top of my head. And sorry for the limited pictures, wasnt planning on doing a how-to on this. I am no way responsible for your actions nor your car if something goes wrong.
Step 1. Lay your pieces out to make sure you have everything.
Step. 2. Disconnect the battery by lifting the 2 tabs to remove the cover. Then with a 10mm socket disconnect the negitive wire. (remember by disconnecting the battery your radio, clock, automatic windows, ecu and other parts of the car get reset. Check your owners manual on how to reset everything.)
Step 3. Remove the front Fasica and the black cover above it by removing the push pins on top of the fasica, there is 12 pushpins. And the 10mm bolts on the bottom. Pull back the fender liners on each side and unscrew the screw holding the fascia on. With a gentle tug the fascia should come off. Place the bumper aside where it wont get scratched.
Step 4. Remove the Fascia mount by unbolting these 3 bolts. This will easier install on the new intake.
Step 5. Remove the strut bar by unbolting the 3 bolts on each side and then pull the 2 push pins on the cover at the top. Pull the cover off and unbolt the 2 bolts under it. Then pull the strut bar out and put it aside.
Step 6. Once the strut bar is removed. Remove the engine cover by unbolting the 5 bolts.
Step 7. Remove the MAF Sensor’s from each intake by removing the 2 screws per sensor, place them in a spot where they wont get damaged or dirty. If they get damaged in any way they will read incorrect and you will have big issues with your ECU.
