From now until tomorrow morning we will be running a special on our new -6 tank to rail fuel feed kits!
Until 10 AM they will be priced at 209 shipped!
Get in on this while you can. Most colors are in stock and ready to ship.
These can be found on line here…
http://streettunedmotorsports.com/parts/stm_dsm_fuel_tank_to_rail_kit.htm
The STM -6AN Fuel Tank to Rail Kit comes with everything you’ll need to replace your old, rusty fuel lines and your stock, restrictive fuel filter from your factory sending unit/fuel tank to the fuel rail. The -6AN Kit works with your factory sending unit and fuel rail.
Our new kits include ALL anodized fittings and your choice of black, red, blue, purple, gold or green Fuelab filter.
If you are running E85, you will want to purchase the stainless steel filter replacement as the paper filter will not hold up to the E85. They can be found HERE - Short 3" 40 Micron Stainless The paper filter will hold up for a short time, but you will definitely want to switch over before 1000 miles.
The Russell ProClassic Hose is so EASY to work with compared to the stainless line. It is extremely lightweight, attractive and you won’t scratch anything in your engine bay if the line is rubbing.
Assembly is required. Often times, you will have extra hose and each car’s set-up is different, so we allow you to cut your own desired length and filter placement. The brackets on the Fuelab filter will allow you to place it right in the factory bolts along the firewall, but you can also run it in line under the car.
-STM
585-730-4314
www.stmtuned.com
