i just bought a tomei short shifter for my 180sx
when i install it for some reason it can be lifted up and down…
vertically… even with the new block installed that holds the dust boot on…
i can fit a snap ring on top of the bush socket… but that wouldnt allow me to put the shifter in the bush socket…
i dont understand… its like the shifter just wont go deep enough into the tranny… but its as far as it goes…-----> YET (as i said it goes up and down… with it up to where i think it should be/to as far as it will go up with the tomei block plate over it… it still shifts perfectly fine!.. leading me to beleive that all i need is a bigger “Collar” or spacer if you will…)
now this is my theory … please help if you can!
basically here is a link to a picture that i need you to look at and tell me if this makes sense to you
http://www.pdm-racing.com/installs/sshifterhelp/sld009.htm
take a look at the “collar”
see how thick it is…
well the one that i got with this shifter i should mention i got it used from an importer in a toyota bag lol so chances are their might be a wrong part?
is quite small… infact its less than half the size of the collar in that picture…
do you think that… that is the reason for my shifter going up and down?
or do you know the size of the one that came with your tomei shifter??
please any help will be greatly appreciated!
