List of leftover parts from the swap
Suspension:
22mm Whiteline Rear Adjustable Sway Bar sedan and wagon fitment (needs a sanding and some paint) SOLD
22mm Whiteline Front Wagon sway bar (needs a sanding and some paint) $125
Rear Whiteline heavy duty endlinks (Sedan or wagon) (c-style) SOLD
Front Whiteline heavy duty wagon endlinks SOLD
JDM sti rear sway bar 20mm, i think this is for the tie-rod style end link not sure the C style will work SOLD
Stock front and rear sway bars with endlinks - make offer
Wagon lower control arms (non recall) OBO
Wagon rear lateral links (probably the same for sedan…unconfirmed) $50
rear trailing arms (probably the same for sedan…unconfirmed) $75
rear subframe (probably the same for sedan…unconfirmed)
Link to struts and springs $125 for struts and springs, 100 bucks for all 4 top hats
http://www.unysoc.org/board/index.php/topic,8989.0.html
brand new OE ball joints (they came in the aluminum control arms but i had a bumpsteer kit i installed) $45 per 80 for both
Drivetrain:
2 front 07 wagon axles $125 for 2, $70 per
3 rear 07 wagon axles (may be the same as sedan, not sure) $125 for 2, $70 per
(for when i thought i was doing an 07 transmission):
2 Front 04 wagon axles $100
04 STI transmission stubs $80
07 WRX R160 Diff 3.7 final drive $250
WRX Driveshaft $100
Stock 07 Flywheel (less than 10k miles on it) $250
Exedy stage 1 clutch (less than 10k on it) $300
Front hubs 60k miles $180 for both or $100 per
07 wrx transmission with 60k miles on it with an unknown whining coming from it (i may pay somebody to crack it open, diagnose it, and fix it, but maybe not)
Transmission crossmember
Clutch slave cylinder can’t remember if we used the sti or wrx…
starter (wires were cut so use your hardware)
Brakes
Link to 4pots, slotted rotors and hawk hps pads
http://www.unysoc.org/board/index.php/topic,10674.0.html
Link to stock (i think) rotors, and hawk hps pads. the rotors may have rust on them and may need to be turned
http://www.unysoc.org/board/index.php/topic,10161.0.html
Interior:
OEM Momo shift knob, verry good condition $65
carbon fiber piston style 5 speed knob $30
Stock wrx e-brake handle
07 sti cup holder/ebrake boot $50
07 sti limited shifter console with aux port and cig lighter with wrx shift boot 50 for aux port, 50 for the rest or buy both for 100 (lol)
60mm gauge pods 20 for both
Other shit not from swap but leftover none the less
stock 07 wrx intercooler
intercooler brackets
intercooler air splitter
hood prop
stock airbox with a good filter in it
