Selling since I have a Klipsch sub I like better. Sub works perfectly. Sounds amazing. Can listen to it before you buy. $175
Here goes the specs.
Product Features
10-inch home audio subwoofer
150-watt amplifier power
28Hz- 120Hz frequency response
375-watt power handling
Shielded for video use
Technical Details
Speaker Type : Subwoofer
Shielded for Video Use : Yes
Efficiency (spl @ 1 watt/1 meter) : 95 dB
Bass Driver(s) : N/A
Speaker Wire Connect Type : RCA & Push Connectors
Design : Ported Design Powered Subwoofer
Power Handling : 375 Watts
Subwoofer High & Low Level Inputs : Yes
Subwoofer Crossover Points : Variable 40Hz-120Hz
Frequency Response : 28Hz- 120Hz
Priced As : Each
Midrange Driver(s) : N/A
Tweeter Driver(s) : N/A
Subwoofer Driver(s) : 10" Driver with Four Layer Voice Coil
Amplifier Power (in Watts) : 150
Nominal Impedance (in Ohms) : 8
Warranty Parts : 24 Months
Warranty Labor : 24 Months
