Just an update to my WTB thread.
I initially went to the importer I bought the car from and he didn’t have any in stock or had any enroute. I have a better feeling about his sourcing than I do about the other dozen or so importers I visited in Montreal last year. I think he felt obliged to help me find another engine since I got my car from him. He went to another importer and did a compression check on a stand alone engine and didn’t pan out - 2 cylinders were at 125. That same shop had just recieved a front clip in immaculate condition and he just finished doing a compression check on that engine this morning. It has readings in the low 150’s on all of the cylinders - no variations by more than 3 psi. The odometer on the front clip shows something like 70,000kms which may correspond to the condition of the front clip. At any rate, I’m going with that engine and it’s hopefull it may be lifted out of the car by the end of today and possibly shipped to the shop in Kingston sometime tomorrow.
I asked my importer to verify the coolant condition and apparently it seems to be a normal occurance for owners in Japan to use predominantly tap water instead of anti-freeze - tropical climate occurance. Hence the crux of my initial problem in the first place. But then again, I think the tap water usage combined with a suspected use of one of those coolant stop-leak products must have been the catalyst for plugging up and/or detiorating most of the coolant pipes/lines. I wouldn’t be surprised that with the absence of real coolant, a stop-leak product might just solidified quite easily and turn hard as rock as in my case. Something one really couldn’t see or find even after some tertiary checking. At any rate, all of thos possible issues will be looked at before the install. As well, the water pump and the timing belt cover will be pulled to verify their integrity and decide then if the 100K maintenance schedule should be applied. As a side note, the engine was mated to an A/T tranny which could mean some other positive prospectives, ie: The inherent charastics of an A/T shifting itself at safe rpm levels would possibly negate the potential for over revving that is highly possible from an M/T tranny. Unless there were a number of mods done to eliminate the rev limiter, then this would be a mute idea. As far as I’ve been told, there appears to be no modding done to this engine that is clearly visable (which is also a good thing). Hopefully, it’ll be back on the road by next week. fingers crossed again
Patrick, it may be worthwhile during your swap to pull the water pump and have a real close inspection of that and the coolant lines/pipes so you don’t encounter similar problems.
