Brand New Samco DV for VW/Audi 1.8T, Color is Anodized Blue. Direct replacement or OEM DV. $125
do u mean forge?
Negative Samco makes awesome valves. I use them over forge as unlike forge they dont need to be disasembled and lubed from time to time.
SamcoSport are synonymous as The World Leaders in Hi-Performance Silicone Hose Engineering.
SamcoSport can now compliment these Hoses with their new range of T6 Billet Alloy Blow off/ Diverter Valves and custom fitting Kits.
Designed in the UK and manufactured on “State of the Art” CNC Machining centres, SamcoSport Blow off Valves incorporate industry leading innovations.
Their unique reinforced Diaphragms and Viton “U” Tech Seals will set new standards in Engineering excellence. These represent an industry first,
prolonging both reliability and Performance.
Twin Piston vent to Atmosphere valves, designed to increase idle stabilization with MAF Sensors.
Single Piston Vent to Atmosphere Valves, designed for Non MAF applications.
Single Piston Recirculation Valves, designed as direct replacement for OEM Valves.
Single Diaphragm Recirculation Valves, designed as direct
Atmospheric venting Diaphragm Valves, designed for Non MAF Applications.
SamcoSport Blow off Valve Fitting kits incorporate marine grade Stainless Steel Hose clamps, Alloy Blanking Plugs, and Race proven SamcoSport Silicone Hoses. (Where Applicable)
The entire range of Samco Sport Hi Performance Blow off Valves is
available in three Hi -Tech finishes, Samco Blue, Stealth Black and Ultra Silver.
Unique Fabric Reinforced Diaphragms
Using our expertise with silicone and high performance fabrics, we have developed our market leading fabric reinforced diaphragms to resist premature tearing, which out-perform OEM diaphragms by factor of 10. T6 Aluminium Alloy Billet Bodies
Using cutting edge CADCAM technology under the TUV TS16949 quality system, SamcoSport Valve bodies are designed to withstand temperatures and pressures seen near the turbo, without distorting.Tempered Stainless Steel Springs
Corrosion resistant and flat ground on either end to maintain the correct pressure, even under the most demanding pressures. Each valve is supplied with extra spring(s) for adjusting idle stabilization.Twin Piston Valves
Specifically designed for turbo intake systems that use Mass Airflow Sensors, the twin piston design maintains the engine’s idle stability when releasing pressure. Low Maintenance Auto-lubricating Viton ® Seals
Twin U-Tech Viton® seals in each Piston Valve are designed specifically to clean, lubricate and seal the piston on every stroke. These seals autolubricate using oil mist generated by the turbo system.
the samco is the same as the forge 007DV(diagphram valve) samco hoses are the same as the forge silicone hoses. both are parent companies in the UK, with US authorized vendors with the Parents namesake.
I’ve never known any forge valve to have been constructed with a diaphram :ponder,(link???) they’ve always been billet piston/valve riding in viton orings in the body bore, at least all the ones I’ve dealt with.
http://www.forgemotorsport.com/valve_service.pdf
Not fightin’, just saying :smile
You beat me to it. I have had and used both. Also disassembled both. Both constructed differently. I think you have some mixed info.
